Old 08-25-2004, 10:35 PM
GadgetMann
GadgetMann's Avatar
Default RE: Tricycle gear question.
Bax & Feihu,
Thanks for the the posts. Unfortunately, the main gear I currently have installed is not bendable. It is some sort of plastic/composite designed to resist getting bent out shape. I could modify the holes the axles are in to lower the main gear. I will definitely look into that. I could also use the stock landing gear that came with the 2nd fuse. As long as it doesn't mess up the balance, I may just use the stock gear and keep the plastic Dubro one in reserve.
