RE: Robinaire 60 Size Rotating Retracts
Hi Richard, and all; They should be able to handle 12 lbs plus. Side rails are the same material I use for 1/5 scale, the main leg tube is 7/16 dia. chrome-moly aircraft tubing. The bottom end with axle is aluminum. Lee
