RCU Forums - View Single Post - Why should I convert to a tail dragger?
Old 08-30-2004 | 09:53 PM
bingo field's Avatar
bingo field
Default RE: Why should I convert to a tail dragger?
On mine, the slab elevator doesn't allow access to the rudder to hook up the springs. That would have been the prefered method, but it wasn't too difficult to hook up a pushrod to it. Look at the picture of the tail in my post and you will see what I mean. I looked at the picture on your site, that is the exact same tailwheel I used. If you look carefully at my post, you may see the lump where I added some 3/16 ply to the underside of the fuselage. (But none of this will help to explain why intelinside would want to convert to a tailwheel...) It was still fun making it work, and flying the result.
