RCU Forums - View Single Post - battery question for a freeflight conversion project
Old 08-31-2004 | 12:21 PM
mrzisme
Default battery question for a freeflight conversion project
Got a quick battery question for you experts. Im currently working on converting one of those $15 guillows balsa kits meant for rubber flight into an rc plane using a gws pico flight pack. Anywho, its a fairly small plane with 24 in wingspan and a full fuselodge (not a stick). My question is, would there be any problem using a 6 cell 7.2 volt 900mAh battery in this little guy? Im guessing that would put me in flight for over an hour, its the same battery pack used in aerobird challenger, is there any obvious problems with using this battery? I saw some people who built a similar sized plane use a 6 cell 7.2 volt 230mAh battery in theirs, same battery setup, except its 670mAh less than the one I'd like to use. Any problems with using this battery in a smaller balsa plane?
