RE: Kontronik Brushless Set 600 - Conversions
Hi John,
I see my Lancair review was published in the October issue of Quiet Flyer magazine. Too bad the editor axed all my flying shots.
I've been charging my ElectriFly packs as a single 6s4p "super" pack through the discharge cable. This disables the SafeCharge circuit. After the NEAT Fair, I plan to remove them from the Little Toni and charge each pack seperately as a checkout. All my big Lithium packs will be re-assessed over the Winter season when I switch to smaller indoor flying.
When high-end speed performance counts, a geared high Kv motor like the Kontronik 600 is best. It will run on 30 cells, if needed, and produce about 1.5 kilowatts of power! The Kontronik 600 is similar, if not identical, in size to the Hacker B50XL.
