RE: Cloud Bound 4
OK Mike, I gotcha.
Port and Starboard side panels are identical, while the top and bottom panels alternate the direction of the braceing members. Looks much better! I would think as you go toward the tail end you would sand an awful lot of those trusses away to keep the tail as light as possible?
Looking good!
Am I corect in thinking that as a modification that Ray wants you cover the truss work with 1/16" balsa? If so it's a pity.
Is there any requirement that you run diagonal bracing members from top to bottom thru the interior of the truss?
Cheers,
Roland Beach
