RCU Forums - View Single Post - I don't get it...
Old 09-13-2004 | 01:06 AM
VA1
Default RE: I don't get it...
[quote]ORIGINAL: TooSlow2Care
"...i drive a touring car (Yokomo MR-4TC SD SSG Special chassis) and with my set up..."
dear sir,
kindly advise your set up. need help on setting up mine. sure the out of the box will slide sideways anyways. but just not satisfied. droop? slip diff? any toe infront? shock oils? spring rate? ride height? pinion size? gear size? motor wind?
please advise. thank you very much!
