RCU Forums - View Single Post - Is my TT .46 pro overheating?
Old 09-13-2004 | 01:19 AM
intelinside
Default Is my TT .46 pro overheating?
Starting to really have a lot of fun with my trainer - can do all the basic aerobatics, loops, rolls, stall turns etc, even if they are not always pretty. Have increased the throws way above the recomended for the rudder and elevator - allows heaps better response. Loving it and can land closer and closer to where I desire.
As a consequence of the more agressive flying, I find myself using a lot higher revs on my TT .46 pro with a 10 x 6 prop. Sometimes I just hold it flat all flight until I land (Up to 10-13 mins).
Would this be overheating it? How do I tell? Should I be using a different prop? Should I make the mix a bit richer to compensate?
Also, the trainer has a typical one servo configeration for the ailerons and I cant get any increased throws out of them. The arms are hitting the hole in the wing. Any ideas on how to overcome this?
All ideas will be appreciated, Cheers.
