RE: Seagull Models Harrier 3D
I'm putting one together right now for a friend. Going to use a OS 1.08 and side mount it. Side mounted engines run so much better then inverted engines do. It is one of the best ARF I've build. Each part was in it's owen box within the main box. It looks as if the parts were laser cut. The plane is small enough you can leave it all together if you have a van or wagon etc.
