RE: First gas engine
It is best to maintain the seperation. Every situation will be different and in some cases you will not run into problems, but in many cases you will. RF can be a pain in the a##.
You can use either PPM or PCM, but set your model up "glitch free" with PPM before using PCM, so if you do have a problem, you won't mask it with PCM.
As for the Fugi, well all I can say is "search function".
