RCU Forums - View Single Post - Troubles
Thread: Troubles
Old 09-24-2004 | 09:01 AM
Jagzilla
Default RE: Troubles
You put your finger over the hole on the muffler to pull the fuel over to the carb, when you are first trying to start it,try doing that first. With a starter box it should pull the fuel in there very quickly. Might also be too long a line between muffler and tank, or between carb and tank. Make absolutly sure lines are hooked up correctly, and sealed tight and in perfect working order. Perhaps dribble a bit of fuel into carb and see if you can start it then, once it's running it should have no problem at all pulling the fuel.
Jag
