RCU Forums - View Single Post - Four Stroke Engine Problems - Enya .53/GP Cessna 182
Old 09-25-2004 | 07:33 PM
Stick Jammer
Default RE: Four Stroke Engine Problems - Enya .53/GP Cessna 182
So far I have been lucky enough to find it everytime it throws it.
I'd say you are more lucky that nobody has been hit by it. As bigchap mentioned, you don't have the prop nut tight enough. Use a 6" wrench and get it tight. There should be some type of jam nut on the prop shaft in addition to the primary nut. Backfiring is usually a sign that the engine isn't getting enough fuel. Do you have the glow driver on constant or does it disengage as the throttle increases? I suppose it's possible that the right circumstances could be igniting the fuel mixture too soon and causing the backfires. Try flying without the on-board glow but definitely get the prop nut tighter.
