RCU Forums - View Single Post - Large composite Mirage Build from scratch
Old 09-27-2004 | 07:11 PM
NickC5FE's Avatar
NickC5FE
My Feedback: (31)
Default RE: Large composite Mirage Build from scratch
OK so i started the mod to make the intakes scale. As you can see from the pix, there is the ancilliary ram intake inside the splitter. The front section of the intake will be removed to assist in the mold, and it itself will be molded. The builder will connect the two. cHECK OUT THE DIFFERENCE IN CROSS SECTION OF THE INTAKES! I am stoked about this project.
ID:	177458   Click image for larger version
ID:	177459   Click image for larger version
ID:	177460   Click image for larger version
