Old 09-27-2004, 07:32 PM
Red Scholefield
Banned
My Feedback: (9)
Default No BS Batteries
I had a chance to look at these packs. No BS Batteries is owned by Steve Anthony who worked for S&R as the head shop guy.
No BS Battery Analysis
Transmitter Pack 8 cell Sanyo 800 AA 2 X 2 X 2 config. Date code IA (Jan 04)
Receiver Pack 4 cell Sanyo 800 AA Flat pack Date code IA (Jan 04)
Receiver pack had 20 mil over sleeve (most manufacturers use 6 mil). Lead wires 8” long awg 20 wire (most manufacturers use 4-6” long w/awg 22 –24). Futaba J connector w/gold flashed pins. Stress relief on lead provided by 1” filament/strapping tape. Weight 101.2 grams vs. 88.1 grams for Futaba 4 cell AA 700 mAh pack. Cell interconnections .187” X .005” thick nickel straps triple welded (Futaba packs double welded Ni-plated steel – some other pack assemblers use .158” wide tabs). See photo. Pack voltage as received 4.48 volts suggesting unformed cells. (Sample not selected for this test). Discharge @ 250 mA after 24 hour charge @ C/10 (80 mA) 991 mAh to 3.6 volt cut off (123% of rated capacity).
Transmitter pack OCV as received 8.34 volts (unformed cells). Discharge @ 250 mA after 24 hour charge @ C/10 (80 mA) 969 mAh to 7.2 volt cut off (121% of rated capacity). Pack over sleeve 6 mil (standard for transmitter packs). Leads awg 22 wire with Futaba J connector w/ gold flash pins. Interconnecting straps.187 X .005, triple welded, cell sticks connected by folded tab. Fiber insulation plate used on each end of pack.
Discussion: The No BS receiver pack employs heavy-duty construction that is as good as I have ever seen. The techniques used result in an overall lower pack resistance than packs using the same cells from other cell assemblers as well as a pack that is more resistant to shock and vibration seen in the R/C aircraft environment. Transmitter packs while essentially the same type of construction as other pack providers are of top quality assembly.
One each of each type tested. Test device – Alpha 4.
Notation for attached picture.
Pack welding.
Futaba pack at top
No BS pack at bottom
Red’s R/C Battery Clinic
9/25/04
