RE: Duraplane conversion
You can swing a bit larger prop and run it on 8 cells. If you are looking for something that can handle crashes well..then look at foam airplanes and steer away from balsa for the time being. Planes made from EPP are very forgiving. Of course you could convert a coroplast plane as well since they are nearly indestructable.
-Mike
