RE: Tuff Flight's 4D
To pick up where I left off on Page 1, I had just cut out the upper and lower fusalage sections.
Next you will need to work on the wiffle bat fusalage section.
First, you will need to remove the wooden dowel in the center of the bat, and drill some lightening holes. But be careful and do not drill out the holes where the axle tubes will go for the vertical and horizontal stab.
Here is a picture of my completed wiffle bat section, all ready for control linkages and the horizontal and vertical stab.
