****There is not much you can do about the transmitter range (at least nothing I know about). All I can say is try to walk toward the plane while flying or try to keep it close to you.
5. After the weight is trimmed and wires soldered up........I glued the fuselage back together with plain old rubber cement. Use as little glue as you can while still making it say together.
http://www.onpoi.net/ah/pics/users/1...058996_mf2.jpg
6. I chose to keep the landing gear and the gear plate off to save weight. I fly my plane in a grass park. That doesn’t really matter anyway because the gear is USELESS. You cant takeoff and land on the gear on purpose no matter what you do so why add weight?
