RE: Tuff Flight's 4D
Let's pick up again where we left off................
I just noticed that I haven't said anything about "ProBond" yet. For those of you who haven't used this glue before, you will need to be aware of some of it's unique properties.
First of all ProBond is extremely effective when gluing foam. It is also activated by the presence of water. This is why the instructions in the 4D tell you to spray the area with water before you glue it with the ProBond. The area to be glued does not need to be soaked, just a little damp. Another thing about ProBond is a little goes a long way. ProBond expands and forms a foam as it dries. It will fill voids. This is one of the reasons it works so good on foam wings, but you will need to wipe away the excess foam as soon as possible. You will need to keep wiping it away until the glue sets up. It is very easy to wipe off with a paper towel. If you don't get the "ooz" wiped off before the glue dries the easiest way to remove it is to cut it off.
