RE: Cam For Aerobird Challenger On The Way (Many Plane Prep Questions)
Troglotech, I'll print out and read over (and over again) your last few messages to make sure I'm on the same page. I'm going on the bases that the regulator is producing some kind of signal noise back through the Xport and you're possible solution to this is the schematic you've just gave me (THANKS), consisting of a few caps and chokes (if I'm reading you right...don't have time at the moment to read indepth the latest posts). Right so far? Anyway, I'll probably order those tomorrow. Tonight I plan a quick test of the regulator with both the diode AND the cap (didn't have the cap on in conjunction with both the diode and the regulator). From what I gather there is only a slight chance that this will solve the problem. I'd also, just for kicks, pick up the 2200uf cap for a quick try. Updates when I have something to report. Thanks as always...
