I just have to report the my Hale walace SkyBolt flew this weekend . A little back ground on this plane . I built it from a sig 60 size kit the differance is I put a ASP 1.08 in the nose . This is my second plane I build . The older members thoought it was way over powered ,as it turns out the plane balanced with no added weight . It is about 10 lbs alittle heavy due to scale details and big power plant . Man this plane flies buitiful at half throttle and loves tyo go vertical . Just had to tell the world .
hers a pic
