RCU Forums - View Single Post - Help with a TT-01 Motor Selection
Old 11-02-2004, 03:56 PM
Karl the Mechan
Default RE: Help with a TT-01 Motor Selection
RUBBISH!
The motor-mount in the TT is made of PLASTIC and has FOUR mounting-positions. This means that FOUR different pinions can be used. In combination with THREE different spur gears this gives TWELVE gearing alternatives.
The plastic-mount is fine for basic motors but if you plan to put in something more powerful you MUST fit the optional "53666 TT01 Metal Motor Mount Set". And the "53664 TT01 Aluminium Motor Heat Sink".
Also the propshaft will flex and rub the radio/ESC, but the "53620 TT01 Aluminium Propeller Shaft" cures that. Now the motor-limit lies in the choise of ESC.
Cheers!
