RE: Lipol-Two - A Kit Bash Project
The tail section assembled very easy. The horizontal stabilizer is reinforced in the middle with a thin plywood stick. The thin plywood control horns were glued into place. The control rod tubing was glued at both ends; where it exits the foam fuselage in the tail and where it enters the balsa servo tray inside the fuselage.
