RCU Forums - View Single Post - Which battery setup?
Old 11-06-2004 | 05:07 PM
Geistware
My Feedback: (16)
Default RE: Which battery setup?
So long as you use one switch for each battery pack then yes, this will work.
ORIGINAL: scubadiver
I'm building a Aeroworks 540t 60/90. I have the following for servos: 2-HS 225BB for the elev., 1-HS 625 MG for the rud., 1-JR NES 507 for the thro. and 2 - HS 5475HB (Digital) for the aileron (one in each wing).
What battery setup should I use?
Is it OK that I use digital and non digital at the same time?
I was thinking of using 2 -1100 NiCad with a y harness, will this be O.K?
