Duralite Regulator Help
I just recently acquired a manual start JG100 engine. The pump battery is a 4.8 v 1400 mah battery. I would like to replace this with a duralite battery. The only problem is the manual clearly states do not use a battery over 4.8 volts. What I need is a source for a 5.1 volt regulator that can handle a duralite but also wired with the heavier connector leads (16 awg) for the battery and the pump motor.
I have checked duralites site but they only have the regulators wired with 22 awg leads, does anyone know where I can get such a regulator.
Thanks in advance.
Patrick.
