RCU Forums - View Single Post - Pipe Question
Old 11-12-2004 | 02:30 PM
patf's Avatar
patf
Default RE: Pipe Question
I have seen the naca inlets quite often. to my best non-engineering knowledge, think this would be the better solution. there is probably a very fine line between a non or negative pressure in the fuse, vs. a positive pressure in the fuse, which i would imagine to be bad, very bad.
edit> i agree with matt in that there are only a handful of builders who could get the fit and finish of all the potential openings sealed tight enough to cause problems.
