RCU Forums - View Single Post - Fuel flow problems
Old 11-21-2004 | 09:39 AM
tIANci's Avatar
tIANci
Default RE: Fuel flow problems
power - start your plane upside down! Also if you really wanna start it normally then do not prime the engine. If you can please use a refueling valve, this will ensure that fuel does not feed into the carb while you are fueling up.
