robart pins
Hi Mark,
You can order the robart pin hinges without pins, or just snip the end of the rivet off and pull them out.
I think the wire is .055 music wire.
BV's new hinges are an improvement on this same theme. You can now remove all of the hinges surfaces from a Super Bandit and I assume from the F-100 as well.
