RE: Rear Mounted Engines, how does it work?
Paul, Good way to describe it!
Something not touched on yet is that a pusher design has an inherent pitch stability with the prop behind the CG. When the aircraft angle of attack is increased, the reaction at the prop attempts to decrease it.
The largest problems to overcome with the pusher are engine cooling and keeping the CG forward with the heavy engine at the rear of the plane.
CJ
