Troubles with new toolbar
I've installed the new toolbar, but I can't get it to work. I check VIEW, then TOOLBARS, then I check RCUniverse. It is checke, but the toolbar is not there. I've looked over to the right, as suggested, down to the bottom, to see if it's hidden.
It's simply not there. I've uninstalled and reinstalled several times, but no luck.
I'm using Windows 98 SE.
The OLD toolbars (I've used several different versions) worked just fine!
If I can't get this to work, does anyone know how can I reinstall the old one?
Jeff
