RE: Reaction 54 Jet Kit
Yeah, John, I'm afraid so. I know it can be de-rated, but there are issues beyond max power. It cannot physically fit in the space between the tail boom and the top of the wing. It could be moved aft, but then you are moving an extra-heavy turbine even further behind the CG, which translates into massive nose weight - kind of a vicious circle. It's truly designed for the 54 class of turbines - that's why I specifically put the number 54 in the name.
That said, the P70 is an "in between" turbine that can be made to work in the R54. The P-60, which is due out very soon, is particularly interesting because it's actually a little smaller and lighter than the typical 54-size turbine and still puts out 13.5 lbs of thrust. Sounds like a match made in Heaven!
Bruce Tharpe - BTE
