RCU Forums - View Single Post - calculating wing area
Old 12-13-2004 | 10:52 AM
Red B.
Default RE: calculating wing area
sdavied wrote:
... However, the surface of an airplane's wing isn't flat. This will require a little more. The easiest way I can think of to figure it would be to use a piece of string. Hold one end of the string on the leading edge. Pull the other end to the trailing edge. Mark each end. Measure the distance between the marks. Use this as the width.
Its common practice to use the wing chord to calculate wing area, NOT the length of the curved surface.
/Red B.
