Can too much power be detrimental?
I am putting a Super Tigre G90 on a small Aeromaster. I was told by the person that I bought it from that I should put at least a 60 on it. I flew another biplane of comparable size with a 60 and it just didn't have the verticle climb that I want in mine. The engine is the same weight and size as the G60, so weight and balence shouldn't be an issue. I'm planning on using a three bladed prop and checked for sufficient prop clearance, so that shouldn't be a problem. Are there going to be any problems that will prevent me from having a good flying airplane with this engine/airframe combination when it's completed such as too much torque or "P" factor?
