RCU Forums - View Single Post - ENGINE/PROP RELATIONSHIP
Old 12-17-2004 | 08:19 PM
TexasAirBoss's Avatar
TexasAirBoss
My Feedback: (22)
Default RE: ENGINE/PROP RELATIONSHIP
Hey Bolt,
Think of your prop as a transmission.
In real airplanes you hear folks speak of "climb" props and "cruise" props.
You guessed it, a climb prop has less pitch. It enables the plane to maitain a better rate of climb.
And a "cruise" prop has more pitch. They don't climb as good or accelerate as good, but they give you a higher cruise speed.
So a climb prop is like "low" gear. Less pitch give better acceleration and climb.
Cruise props are like high gear. And have more pitch.
If a plane is very streamline , it will actually fly well with a prop with very high pitch. The same prop and engine would be overloaded on a bluont and slow plane.
Aerobats like to go straight up and straight down. They use climb props, less pitch. And the prop can act as a brake on the down leg as well.
The charts listed above show a range. Just what you use in that range depends on your plane and your needs.
Often I will play around with 4 o5 props until I find the one with the best performance for a particular application. When it is right, the difference is more than just noticable.
