RE: KMP 87" Yak-54 What do you Think?
Well, I have been busy on my Ultimate, but I did get a chance to go check out the building status this evening of project KMP.[8D] Engine has been mounted, and now the firewall is ready for fiberglass. That MVVS is a sexy piece of equipment man!
We do have a complaint. They glued triangle stock to the back of the cowl tabs??????[:-] I am not a fan of using wood screws for cowls. I'd rather run blind nuts and 4-40 bolts with the neoprene stamped washers to realy grab the cowl. I believe he’ll have to either sand a flat spot on the back of the tab, or glue an inverse piece of triangle to get the surface angle back to parallel.
