RE: Regular servo as retract servo??
unless you have it set up PERFECTLY, it will bind on the ends and drain your battery very, very quickly. (possibly minutes...) also, retract servos rotate 180 degrees, so at the end of the travel they have incredible power due to the mechanical advantage, enough to free landing gear that is stuck...
