RCU Forums - View Single Post - Pull pull rudder setup question...
Old 12-27-2004 | 09:45 PM
a65l's Avatar
a65l
My Feedback: (17)
Default Pull pull rudder setup question...
OK, I'm setting up the rudder for a Zen 50. The stock cable exit holes in the fuse are a touch farther aft than they should be, so I used a couple of pushrod exits to smooth them out. Problem is that the run of the cable isn't perfectly straight, but I can't move the exits foward, as there's a frame in my way. My question is, can you cross the cables, I.E. run right horn to left side of servo horn, and vice versa? I know full sized aircraft use this system, but are there any drawbacks/negatives about doing it in r/c? IT would make for a much straighter shot at the control surface, or would I just be better off letting it rub?
Thanks in advance,
Andy
