RCU Forums - View Single Post - Radio setup for U-Can-DO 46
Old 12-30-2004 | 11:15 AM
Pathogens
Banned
Default Radio setup for U-Can-DO 46
Hi all, I got a U can do 46 with a saito 82 on it and am looking for some help with some radio setup questions.
I am running a JR 9303 with an Hitec Electron 6 receiver.
Question one. I have 6 servos on the a/c but my receiver is only 6 channel. I would like to be able to hook all the servos into the receiver and then use the radios mixing functions to mix the different channels together to get it to work. Basically, I would like to have subtrims and all that good stuff aviable. So I can plug in all the servos, but what do I do with the battery. Can I Y harness the battery and servo into one channel? How is this done?
Secondly, If i choose to not plug all 6 servos into the receiver, I have 2 options as I see it. I could use a y harness like the book says and connect both alierons together. OR I could connect both elevator servos together with a y harness. What would be the benifit/cost of doing it either way. Do people some how mix their elevators with their alierons? I would like to be able to use flaperons mix. Maybe some one can acutally explain some of the common mixes and maybe short explanation for each, such as flaperons. Why does the u can do manual say to use y harness on the alierons but doesn't mention anything about possibly using a y harness on the elevators. would I want my elevators on seperate channels or would I want the alierons on different ones? benifits of each?
Thanks in advance.
