RE: Radio setup for U-Can-DO 46
Installing horn on elevator servo 180 degrees out may not be possible as arm will be too close to elevator. Better idea is to install one servo with output shaft pointed foward, and other servo with output shaft pointing aft. This will have the same effect, and will allow you to have the horns pointed down for max clearance from stab and straighter run to horn. You'll still need one rod to be longer than the other, but wire is cheap and easy to work with.
Andy
