RE: Working Nav Lights
Here is some good info, may be a bit small, but is very easy to make and weighs next to nothing. The system runs off the receiver battery and has very low draw. Best of all, it is very cheap to build> If you look through the thread, you will see links to companies selling ultra-bright LED's which would work better for your size plane. I put this system on a slow stick and it does very well
