First I would like to thank all that offered advice to my inquiries. Thank You. Second there is a video on
http://www.geocities.com/v22chap/vtol that shows his model in flight. Yes there are huge questions about control because at one point it is neither a plane or a heli. The only answer I see is to be sure it is flying fast enough to be a plane before quiting to be a heli. Also note that the prop/rotor blade does cover all but 1 inch off the wing(inboard) I think this is possible,not easy or assured but worth trying.
I assume the flaps will need to be flat verses a slight downward curve since they are also ailerons?
