OK when you glue to butts of wood together, like say gluing fuse sides together in the pt-40 trainer kit you would put the pieces together then put CA on the seem and it will seep in to the wood and stick. if this is the right way then i glued my pt-40 together wrong cause when i put my pt-40 together i put glue on the ends THEN joind them together. oh well im probably going to by the kit again anyways cause i built it when i was like 10 and did a horrible job on it but im 16 now and would like to try again. (PS right now its siting in my room half finished and its been in storage for 5 years, use your imagination
) so what are your comments on this
