RE: Loaded Voltmeter ?
Redrum, that is normal as the battery is continuously discharging through the load resistor. Hold the button for a few seconds and take a reading. The rated loads (.5,1.0 and 1.5 A) are based on a 6V battery. So. if you're using a 4.8V battery, the actual load is slightly less than the rated.
