RE: Please Help. Need Senior Telemaster CG
Hi,
Glad you got the plane down with no problem. You need at least a 90 glow 2 stroke or a OS 108 is great.
If possible, make some straight spars and remove the dihedral from the wing. Also, set up your ailerons with mechanial differential.
Then the plane will fly a lot better.
Elson
