RE: ParkZone Super Decathlon Review
It takes longer to charge the 7-cell, 600mAh NiMH flight pack than it does to assemble the plane. I simply installed the eight AA batteries into the transmitter and then pushed on the pre-finished landing gear into the fuselage bottom.
The control linkage comes ready to go on the lowest throw setting. Since the transmitter has a dual-rate switch, I decided to increase the throw range by moving both the elevator and rudder clevises to the 3rd hole from the end of the control horns. The clevis was re-adjusted outward (by unscrewing it a few turns) to re-center the control surfaces after first centering the transmitter trim tabs.
