Foxtrot_019,
First look at the following thread here in this forum. It has a wealth of information in this size plane.
http://www.rcuniverse.com/showthread...730&forumid=31
You will also want to brouse the forum for additional information. The Edge has a good reputation in 3D and the Extra has a better one in precision flying. My personal favorite in 3D is the CAP232. If your choices are narrowed to the Edge or Extra and the purpose is to learn 3D then by all means go with the Edge. (I
don't believe that I recommended an Edge to anyone!)
I don't put a lot of points on the landing characteristics of a plane for IMAC use. The landings aren't judged. The CAP is more difficult to land than the Extra or Edge. If you learn to properly land any plane and can fly it you should be competent to land. If this isn't the case then go practice landings and learn to use the throttle to land along with the rudder. If you don't the result will generally be the same and end with a newly kitted plane.
Opinions are like noses ~ everybody has one. This one is mine.
EXCAP2322
