Ryobi 31cc - How do you start it?
Ok,
How do I start this thing without having to put on an electronic ignition.
I have a 18x6 prop on it with a bolt (short shaft ryobi).
I have a drill with a starter cone but with the bolt on the front it does not have anything to grip.
I did see a suggestion to drill and tap the prop bolt in the center and put a nose cone that has a center screw on it.
Any other suggestions?
I have not gotten the engine mounted and will probably try to test run it on a stand first.
Also, does anyone have a picture of the fuel tubing on this that includes the primer bulb?
Bill
