RE: E-Flight ultimate 3d video enjoy
Hi Devin - I'll have to check again but I believe its balanced on the horizontal cf rod that goes from the side force generators to the fuse. To be honest though I'm really not sure. I put a long enough piece of velcro on the side of the fuse so I can move the battery fore and aft, and adjust the cg. (I have a few different size packs) I'm away from home right now so I don't have access to my planes - otherwise I'd check for you to give you a better answer. The Tensor at the ideal Cg should exhibit minimal or no pitch coupling with rudder, and just a little roll coupling (i forget if its proverse or adverse).
hope this helps - next time I go home I can check
jon
