ZDZ 40 - No Fuel!
If flipping the prop works, why wouldn't using the starter work?
Cover the inlet to the carb (tape, foam, whatever) and see if you can get it to draw fuel that way. If that works, it may be an air leak somewhere. Maybe even the hole in the choke butterfly like mentioned above.
