RCU Forums - View Single Post - Pull Start Problem
Old 01-12-2005 | 09:32 PM
UKownsU
Default RE: Pull Start Problem
I finally got it fired. I took the engine off the car and rigged the shaft to a drill. I had someone run the drill while I put after run oil in the engine to keep it lubricated. After I did this, the engine was loose enough that you could actually use the pull start. I tried the hair dryer first and that did not work. I heated the engine up so hot I had to wear gloves, but it was not enough. After this, I will not be buying anymore pull starts.
