RE: Hitec Digital Servo Programmer vs Futab TX
Bentgear. While you are absolutely correct, (pattern ships would be set up differently you still have to pay attention to mechanical advantage/disadvantage. On the other side of things, you could program your servo to move 10 degrees while your control surfaces are moving 25 degrees. Not good.
Maybe we should have been clear on what kind of plane we are programming for. When hilleyja said he got his info from Joe Hunt, it was clear that he was referring to 3D because I saw the same video.
